Question on curves for an SRX
snopax
Wisconsin
Hey guys.. Just got my hardware kit from curve and I had a question to anyone running curves on their srx. First, which way is the rubber supposed to point, tal side front or back. Also, I have a fair amount of space between the rubber and the rubber cradle on the ski. Is that normal, or should the rubber completely fill the cradle?
Mine is higher in the frt. Hope that helps. I beleive its so it puts more downward force on the frt of the skis.
Is there any #s stamped on the rubber? I remember this last year. IF the higher part is in the rear, The ski wont touch the ground intill about 2 inches behind the spidle. So deff mount it in the frt. Just mount the spindle in the rubber and shim if needed with washers on each side.
