ReaperSRX
I have longtravel'd & longtracked my 2000 SRX 700, because of weight issues (my fat A$$), i really have to crank up the preload on my rear spring, i was told that the Viper spring has similar rate but is longer, if so would the longer spring give me more ride hight even though the rate would be the same....if not i think i will need to get stiffer rear spring..........James
are you putting this on a short travel shock...the longer spring??
ReaperSRX
No, it would go on my longtravel'd SRX rear shock, so is the viper spring longer and would it help with my problem or should i just look at stiffer spring.......James
its worth a try but I would maybe go with a stiffer spring...
ReaperSRX
Thanks, i think i will just go with stiffer spring, as far as i know the 2000 SRX spring was 2.8 - 4.8 so i think i will try a viper 3.0 - 5.0, now all i have to do is find one............James
