Viper Top End rebuild
srxman06
shakopee,mn
Going to do a top end rebuild on my 02 Viper. Wondering if i should go OE or aftermarket on the parts?? Any suggestions on any other things to do to it since i have it apart?
not too bad with the support found here. You will be glad you did in the end. then u know what u got. how many miles on motor ?? Go with OEM pistons & rings & gaskets for sure.
It is really not a bad job to rebuild the top end and bottom end of the engine. I am in the process of assembling three 2000 SRX 700 engines. You will get a ton of help and advise from the experienced members of this site. One engine had 13000 miles on it and suffered from a lean burn down but I was planning a complete rebuild anyway, could have done without all teh damage though. The second engine had about 1800 miles on the odometer but I bought the sled used and found some suspicious examples of shoddy work on the engine so I decided to disassemble it, inspect it and replace all the gaskets, seals and rings. The third engine is a spare which I am assembling from a variety of new and used parts.
With 4000 miles on the clock, it is definitely worthwhile to check teh entire engine. It is cheap insurance against having a worn seal cause an air leak resulting in a lean burn down which will cause expensive damage.
I sent the crankshafts from all three engines to Jeff at Midwest Crankshafts to have them checked/repaired. Again, cheap insurance to do the job right.
Can i hone the cylinders myself or should i take them to a machine shop? i think the cylinders are nickle plated?
no need to hone.. Just deglaze them with a red 3m scrub pad. Cross hatch should still be visible. If not, send it out for a replate.
