mattyg1405
i need a jackshaft bearing the one thats behind the secondary, does anyone know what kind it is or if it could be replaced with a bearing from a local bearing manufacturer?
im wondering if theres a model no or something i could try and hunt one down tomorrow since i have to have the sled together ASAP
the number I have for the jackshaft bearing(NTN Bearing) is 04-156-040R.It comes with the collar.Don't buy a bearing that is made in China..either from the USA or Japan.
IIRC that bearing is on the driveshaft as well. I got mine from motion industries. Lemme double check the numbers. I got a timken through them.
yamaha Part#93306-20589 Axle bearing UB205 Japan or Fafnir #YAE25RR
Try that bub...
If not remove the bearing and cross them that way...
Try that bub...
mattyg1405
It's a locking collar correct??
the collar locks down with 2 set screws..red locktite them into place.I screw up a shaft because I didn't locktite the damn set screws.....
mattyg1405
the bearing i put in was a little different it had a 2 piece locking collar, they were off set.(the bearing from the coller, and had one set screw
bluewho
That would be a polaris bearing you have installed.
mattyg1405
its all the bearing distributor had! i think itll be fine everything but the collar was the same
bluewho
Bin there lol i think i used some shim stock to fill the gap than tightened the set screw on that.
I am currrently in the process of changing all these bearings. I am stuck on pulling the jacksaft. I have searched the forums but have not come up with the exact answer. Do I need to pull the skid? I have the chaincase off but now I cant get the shaft out. I have loosened the track but it still seems tight. I have loosened the set screws under the tunnel. Thanks.
mattyg1405
YOU mean the drive shaft?
super1c
Super Moderator
If your talking about the drive shaft you dont need to remove the drive shaft to replace the speedo side bearing. It will slide out the speedo hole on its own. Just take out 2 set screws and a bit of a nudge from a bar and it will slide right out the speedo hole. I take mine out every year to grease. If you want the whole shaft out you will need to pull the skid. If your doing all this work you might want to pull the skid and go through that also.
Ya, sorry I meant the drive shaft silly me. I got the bearing out. I didnt realise the shaft would stay and the bearing would come. Thanks
