Hi,
I want to get the springs off my Ohlins shocks I bought for my 99 SRX.
I bought a shock compressor, put the Ohlins in there, but when rotate the long arm of the compressor, at about 1 o'clock it hits the frame for the piggyback shock. The spring retainer is loose at this position, but cannot be slid far enough towards the center of the shock to remove it.
Any suggestions?
Picture attached..
Any suggestions?
Picture attached..
i did mine by hand just unscrew the locking collars and taking tension off the spring
super1c
Super Moderator
Front shock should not need a spring compressor. Just like YA*AM*A*HEAD said, just unscrew the locking collars and it will slide off by hand. Only shock that needs a compressor is the big rear skid shock. A flat screwdriver and a rubber mallet will unscrew those collars enough to make them loose and the rest by hand.
