A
AIRWOLF
Guest
I have a 98 srx700 , i just bought a used Bender cold air kit, What should I be using for jets? I ride at sea level,Mod's clutch kit ,,,.015 shaved off heads,
Main's??
pilot's??
needles??
thanx
Main's??
pilot's??
needles??
thanx
Brad
- May 23, 2003
Jetting
ok this is the info from the bender install instructions
WITH JUST THE COLD AIR INTAKE 147.5,147.5,AND150 MAIN JETS
WITH COLD AIR INTAKE AND AIR BOX MOD 150,150,152.5 MAIN JETS
LEAVE THE REST STOCK
I am running 148.3-148.3-150 in my 98 700 srx with cold air kit & a 2" wide opening in my airbox shelf. Plugs & wash look good. This is at 1800' elevation & -5F.
Brad
- May 23, 2003
Jetting
HI TURK, I HAVE THE BENDER INSTRUCTIONS RIGHT IN FROM OF ME
IT SAYS FOR THE AIR BOX MOD GUTT THE AIR BOX(TAKE OUT THE INSIDE TRAY AND DEVIDERS) AND CUT A 1.125 WIDE SLOTS THE SAME LENTH AS THE STOCK SLOTS AND THE 150,150,152.5 JETING IS GOOD FOR 0 DEGREES F.JUST GIVING THE INFO FROM THE INSTRUCTIONS I TRIED TO SCAN AND POST BUT I CAN'T SEEM TO FIGURE IT OUT
THAT'S THE SET UP I HAVE O DEGEES F = -17 DEREES C AND I RAN MINE AT -25 DEGREES C AND NOT A PROBLEM
A
AIRWOLF
Guest
THANK YOU!!!
