97 vmax 600 oil pump
marc8_2
ottawa
Is it possible to take out the oil pump block the hole and just mix the oil with the gas??
why would you want to just replace the pump with a new one and it fixes the oil pump problem. It feeding it to much oil right?
97 had bad pump design. Make sure you replace the pump with a 98 pump. To answer your question, Yes you can take the pump off and cap the line. I ran my 97 with that fix for 2 years with no issues.
