need some help
coryv4
Michigan
ok i adjusted my suspention on my vmax to where i sit on it and it slightly goes down but my transfer rods bottom out the second any weight is on my sled will this hurt any thing?
super1c said:
You usually adjust the spring to get a 50/50 gap on the rods when sitting on it. Meaning a equal gap on the top of the rod and bottom.
well i am trying to get this adjusted so i can get the skis up easier every time i hit a drift or somthing the front end wants to stay planted and it just makes me dig into the snow i need some help on how to get it to pull up easier also it has full ohlins suspension if that helps
Let out the limiter straps as much as you can and stay in the corners. Or if not a big trail rider leave them real loose. Just remember your ski pressure will be very little and turning will be tough.
my limiter straps are as far as they will loosen ive watch the proaction tuning video and adjusted it to transfer the weight to the back of the sled and it never made a difference
