600 valves being turned to 780 (pete)
YA*AM*A*HEAD
indiana
srx 600 valves turned into 700 valves ...just gotts cut them into 780 valves ...
yes rich the welding was done to repair what someone cut out of them. I only need the blades cut for the 780. I can have the rest machined.
i have machined down the welds ..one valve the weld was not high enough its 0.0225 too short ...wish you would have welded all the way around would have turned out a little better ....monday they will go in the haas cnc mill to be cut for the 780 pistons .....i might go ahead and tig them all the way around and remachine them just gotta see how busy the shop is
thanks they were ugly for sure if they can be saved go for it. you r a wizard. I have a set coming from fusion69 so no big rush. thanks for all your work Pete.
