got a viper dead spot on start
696viper
Ohio
hello i have a 2002 viper if you just give it full throttle right out of the gate if will boog down almost stall but if you slowly raise the rpms it will run fine if you are ridding its fine only from a dead spot what could be causen this problem :letitsnow
i have cleaned the carbs try it again what about exhuast vavles would they have any thing to do with that
Try flipping the choke on/off and see if it picks up faster. If it does, than the pilots still have blockage in them.
Many a time I couldn't get the pilots clean by spraying through them, I have to actually run a small wire into them to get the gunk out.
X2^^^^^^^
Stock on the viper is 1 7/8 out on the fuel screws. Try them all at 2 turn out. Also make sure the carbs are synced. Sync to the middle carb. Plenty of info on that. Let us know how you make out.
k thanks going to try that today or tomorow any no what size the pilot jet is i might get 3 new ones clean old ones and have them for a spare
i agree just wanted to get a new set two they arent much just to have a spare set so u think they are 45 thanks
