oil pump question
Yamahasrx700
Channaho, Il.
How long does it take to purge a new oil pump? I bled the pump and got the air out. How long does it take the oil to reach the fuel pump? I put new clear oil pump lines.
Bleeding it only gets it to the pump. The pump has to push it up to the fuel pump from there. Basically start the motor to spim the pump. Not sure but u could prob. pull the plugs & pull it over multiple times then check your clear line.
