srxman06
Will a 1.5" lug track fit on the viper without having to change anything?
sure will as long as you have no heat protectors
srxman06
the ones on the tunnel?
No the ones in the front by the drive cogs
SXViperFanatic
I did it. Took a grinder and a hammer to get the heat exchanger guards off. You'll have to remove the plastic stud protector strips on the top of the tunnel too.
SXViperFanatic said:I did it. Took a grinder and a hammer to get the heat exchanger guards off. You'll have to remove the plastic stud protector strips on the top of the tunnel too.
Seen it on this sled, worked like a champ. You should see the snow flying out the back of his viper when im looking back at him...hehe.
srxman06
bought a used track but just noticed that 1 row on the inside where the drivers go is all chewed up. Do you think this will cause a problem?
mattyg1405
should be fine but post some picssrxman06 said:bought a used track but just noticed that 1 row on the inside where the drivers go is all chewed up. Do you think this will cause a problem?
jgustman
I tried it, didnt' work on my '04 viper s...It kept hitting the front cooler slightly when letting off the throttle and hitting bumps. Made a lot of noise but no damage, I took it off and bought a cobra. The 1.5 sapped my top speed a ton....
