furg69
Looking for some help with a 98 vmax 700 with simons triple pipes. The sled has pipes, reeds and proper jetting. The helix says 'Advant' on it. im wondering what the primary and secondary spring should be, along with weights. Thanks for any info.
I would use 8ca weights if you want it aggressive, need to know what size the helix is theres other letters numbers on it, that information will decide which springs use you and what rivets to place in weights as youll need to run that engine at 9000 rpm with those pipes. Those pipes are rippers when set up right!
