ohlins? will they fit?
jbsk731
antioch, il
anyone know if ohlins from a yfz-450 will fit on an srx 700 their 15.75 center to center and 10mm bolts top and bottem? also have dual springs
thanks in advance
motorhead327 said:
Did you try it? I have been waiting for an update from your last post on this!
I bought a set and found out they won't work on the Viper, the top shock mounts are different than on the SRX. PM "amatosrx" he's running kfx450 shocks which is basically the same the YFZ450 on his and seems to love them.
I'm still trying to figure out a way to make em work and will post the outcome if I can crack the code.
SRX
Viper
So you're in luck motorhead, I see you ride the SRX If your interested I have a set of shocks in awesome condition and it looks like you're close Clicky clicky
:letitsnow
so with an srx the factory shocks off say most 450 or 700 sport quads should bolt right up, be less expensive, have longer travel and have more adjustability? sound about right???
awesome, someone picked up the ohlins i was looking at but found a set of fox floats with ressies for 270 shipped their 16in center to center. Im guessing the 19in c2c would be to long?
Take out your stock shock and measure how much sag there is and that your answer your question
SRX
Viper
:letitsnow
Hey I think those are my ohlins I had for sale.
