I currently bought a used primary is there any way to cross referance the numbers to see which sled it came out of?
the clutches are usually the same unless you are talking about the 80's sleds or something.Only things different are the internal parts..ie:rollers,weights. I have a primary that Turk sold me and it comes off a turbo sled.They look the same from the outside.
some of the older ones do not have mounting locations for starter gear rings.
The only thing i noticed different was the set screws for the bolt going through the arms on the primary arent there on the used primary. I plan on changing everything. any setup recommendations?
I have 3 primaries here..only one has no set screws as you mentioned..
if this is for an SRX..try the 8bu-10 weights,better then stock for pull.
Yes it's for a 2001 srx. Im going to change springs, helix, weights everything. since i only have the shell of the primary now is a good time to replace everything. i am also thinking about changing the gearing. i'm a big guy at 210 and i need this thing to luanch out of the hole like no one businesss.
