96 Vmax heated shield hook-up
Excitabletom
Grand Rapids, MI
I just got a heated shield helmet and it came with the wires, but no directions on how to wire it in to the sled. Can someone tell where to hook up my two wires? I see no "easy" or obvious spots when I look under the hood.
Thank you.
find the wires leading to the tailight. there will be a plug under the seat or you will find the wires just below the fuel tank. theres a blue, green, and a black.
black is the ground, blue is the constant power. tap these and you should be good to go. you can also locate the same wires under the bar pad leading from the brake switch.
