So I'm rebuilding a 99 SRX and had the center cylinder blowout. It was pretty scratched up so i took a hone to it until i was about .001" under the cylinder wear limit (2.72" ID), and i still have score marks. the marks appear worse at the top of the stroke and near the ports.Some of these scrathes you can feel with a fingertip. So My questionis,: Is this thing good to use as shown? I'm getting a new top end set, and thought i may just chuck this and get a used cylinder and not have to worry about it.
staggs65
I wouldn't chuck it. it's still a good core if you do an exchange through one of the replating companies. but yes I would get another one, used or replated.
OK Thanks, i didn't even know that was an option to exchange it. i could get a used cylinder for around $200, so i will probably do that. How does the exchange thing work? i.e. I send them a damaged cylinder and they provide a remanuf unit. Then then remanuf my unit and sell it?
That's pretty much how it works.
HERE YOU GO http://mt-llc.com/
rx1jim
The exchange process works exactly as you described it. The cylinder suppliers will only accept stock cylinders for the exchange. If you have a ported cylinder, they will not accept it for exchange but will rework it for you.
ok good advice. hopefully have this rebuilt by christmas, now to find a puller for the CDI..
