larger front suspension
88 yamaha 570
Bridgeport, NY
i was wondering if i would be able to put these fox shocks i found on a 98 zr600 im parting out, i plan to install rear skid in the sled but was wondering if the front shocks will fit in my 98 srx without modification... they are 17" center to center, the bolt locations are about 3/4 of an inch thick. i do not know anything about these shocks but have both front and rear, one of the lines for the rear runs under the primary clutch and just ends... is there supposed to be an adjuster there?, if someone could give me some information on them for how much they are worth or if they will fit please let me know... thanks
Anything can be made to fit but for your stock mounts, 14.5 to 16 is about it for adding longer shocks unless you change brackets
If you put sxr radius rods on it they would be closer. It would still sit really high though. they look like they are decent shocks too.
sweet, i found them n a sled i paid 200 for... what about the rear one? there's a shock with 2 braided lines, one runs into a little box thing and the other runs under the secondary clutch and ends...
ottawaair said:
it used to go to an adjuster by the handlebars. Does the end have a coupling, like an air hose coupling ?
yes sir... suspension really soft too so im assuming i need the adjuster to get it harder? how much does it cost and does anyone know what its called?
