Is there any fix for the speedo if you swap from 9 tooth to 8 tooth in a srx? Thanks
9801srx
you need to get the speedo adapter off a sled with 8 tooth drivers.
musselman
x2 one off a mountain max should work
ottawaair
i used one from '01 mtn. max. stock 8 tooth drivers.
Finally ordered my 8 tooth drivers today. I looked on the micro fishe and have no clue which part to order. Is it the piece that comes off the cog shaft? Thanks
Grind some teeth off of the speedo gear. Start by grinding off one tooth and check it by comparing to GPS speed. If still off, grind off a second toothon opposite side of the speedo gear.
This worked for me, I needed to take 2 teeth off of my speedo gear to bring it into a more realistic speed. The speedo still reads a little high, but closer to GPS speed.
no gears to grind on the srx, that appies to the vipers, rx's and others with the digital gauges. for the sweep gauges, as used on the srx's and others, your looking for part #8DP-47700-00-00 for 8 tooth drivers.
snowdad4 said:no gears to grind on the srx, that appies to the vipers, rx's and others with the digital gauges. for the sweep gauges, as used on the srx's and others, your looking for part #8DP-47700-00-00 for 8 tooth drivers.
Sorry about that. I didn't even realize that they are different since I don't have an SRX (yet that is).
