Cracked bulkhead
007SRX
Ontario
So as I dig deeper into my 2000srx i bought in the spring, I have yet again found more wrong with the sled. I was trying to replace a bent trailing arm but the bottom radius rod is seized to the trailing arm. So I wanted to remove the rod from the sled to either work on it at my shop or just replace it. While removing the bolt retaining the rod in the bulkhead I noticed a lovely little crack in it. Gonna ride this year and keep an eye on it and hopefully tear it down next summer and weld it. My question, can you weld these bulkheads with good results ? Also, to get the radius rod out I'm assuming you take all 4 out at once ?
TIA
You have to loosen the 4 bolts off to allow a rod 2 be slipped out of the holder after the bolt is taken out of course.
Weldable if you make room to get in behind.
