fuel shut off valve
gf7duster
Ontario
Can someone tell me where the shut off is on my 2003 viper
Trying to fire it up and can't get any gas
Must have shut it off in the spring but I'm getting old and don't know where it is now !! Lol
Did you put one on it, they didn't come with a shut off!
Chances are its been sitting all summer and needs the carbs cleaned.
Also sometimes the pump needs a prime if its been sitting dry for a long time.
X2, no shut off valve. After your carbs are clean you can rotate the primary clutch back and forth 5 or 6 times (clockwise / counterclockwise). This will prime the fuel pump and start in no time. A little trick i pick up here that has worked like a charm for dry fuel lines.
