I talked to a friend that told me that he took the air box off ( viper)and sprayed BRAKE CLEANER into the ports that connect to the PILOT JETS and he didn't have to take the carbs off to clean them out.. The BRAKE CLEANER WORKED... He took the straw and blew brake cleaner right into the ports.... He said it worked FINE... ???????
Macheater
Uh, ya ok. And to think, all these years I've been doing it the hard way.
It depends how dirty they are. The cleaner may disolve some varnish. But if you are going to bother taking the airbox out you might as well remove the carbs and do it right. 30 minutes of time to prevent a burn down is worth it. Besides the needle valve needs to be cleaned anyway. No way of getting at that with the carbs on.
its not just the Pilots that need cleaning....that is the lazy mans method..not fool proof.You have to get dirty to get it clean.I clean mine complete at beginning of season and run good fuel.My carbs stay clean the whole season then.Now you guys that run with ethanol..that is a completely different beast to contend with.You probably have to clean carbs after motor has been sitting without run time after 2 weeks..
SX700triple
2upperDeluxe
I.d.i.o.t.
edunn69
GREAT IDEA!!!! Blow the dirty that is plugging the carb back down into the floatbowl so that on the first ride you can suck it back up and plug the same jet = BURNDOWN! LMAO
bolin22
I Assume Nosboy Is Trying To Do Some Phishing Here While He Is Waiting For The Latest Oil Scam To Come About
you got that right...edunn69 said:GREAT IDEA!!!! Blow the dirty that is plugging the carb back down into the floatbowl so that on the first ride you can suck it back up and plug the same jet = BURNDOWN! LMAO
Macheater
Not to mention the initial startup on some unknown quantity of dirty brake cleaner instead of gasoline. Wonder how much of that brake cleaner made its way into the engine during that gunk down & carb cleaning?
DoubleClutch
I see a engine rebuild in your near furture if you do it that way!!
sockeyerun
Test Dummy
Pulling the carbs is a nusance, rebuilding the motor is an expensive.
I can pull the air box and remove carbs,change jets and re-install everything in 45 minuets..not to bad.
akrievins
Bluemonster1... wanna do mine for me? A short trip to Ontario.
I wish I could jsut see someone do it once... Any video's out there? then I could do it no problem!
how long have you been sledding..you mean you haven't tackled it once.Pay the air fare and I am on the way...lolakrievins said:Bluemonster1... wanna do mine for me? A short trip to Ontario.
amatosrx
VIP Life Member
stupidest thing I ever heard. just do it right.
Super Sled
TY Off Trail Expert
Hey guys, who cares how another guy cleans his carbs. Really, who cares. If youwant to disagree, fine. But this cutting a guy down part? I don't get it. This name calling is ridiculous.
snomofo
VIP Lifetime Member
Super Sled said:Hey guys, who cares how another guy cleans his carbs. Really, who cares. If youwant to disagree, fine. But this cutting a guy down part? I don't get it. This name calling is ridiculous.
X2 - I too think it's silly, dangerous or even a bit lazy - but idiot and stupid?
Sheesh.
Personally, I thought it was a pretty DUMB IDEA.... just wanted to get some opinions if anyone ever tried it??? He's a guy that I snowmobile with that doesn't want to repack his wheel bearings ... He thinks they will be just fine ...bolin22 said:I Assume Nosboy Is Trying To Do Some Phishing Here While He Is Waiting For The Latest Oil Scam To Come About
Such a bad idea. I always take mine apart.
I took mine out this season, just for piece of mind (even though I treated with stabil). Low and behold, there was sludge buildup. I think some of the gas evaporated and left behind deposits.
