doing rings on viper
696viper
Ohio
got a question doing rings on my 03 viper got new base gasket and head gasket and rings what else do i need to get before i tear into it and forget something thanks :letitsnow :2strokes:
X2, ex manifold gasket. Be sure to hone the cyl's lightly before reassembly. Grab some coolant, u will lose some in the process. Make sure u bleed the coolant system when done.
on the rings, there will be a little "T" these go up on the piston, the top and second ring are the same.
clean all surfaces good and make sure u oil all moving parts with the oil the rings needle bearings and the pistons real good.
