justin1620
I need to replace my Max Performance red primary spring.  Does anybody know where I can get this spring or one that is equivalent?  thanks
			max is long out of bussiness so a new one is not likely unless someone has old stock. The red maxx spring is 52.5/130 kg. The closest yamaha oem spring is the yellow-white-yellow which is 45/128kg, so your engagement speed will be down. The final shift will be very close. You could use some spring shims with that spring and be very close.
			justin1620
thanks mr. viper.......I also have a brand new hauck black primary spring.....would that be better or should I stick to the yamaha yellow-white-yellow w/ a couple of shims....thanks
							mopar1rules
I personally would use the hauck black and use 1 or 2 engagement shims as the replacement to the no longer made maxx red.
			mrviper700 said:max is long out of bussiness so a new one is not likely unless someone has old stock. The red maxx spring is 52.5/130 kg. The closest yamaha oem spring is the yellow-white-yellow which is 45/128kg, so your engagement speed will be down. The final shift will be very close. You could use some spring shims with that spring and be very close.
With stock clutching, what should engagement be? Manual calls for 4,200 but mine is more like 3,800.
YAMMIEGOD3:16
THOSE MAX SPRINGS ARE WORTH THEIR WAIT IN GOLD. I MAY HAVE A USED RED. probley don,t help. 3:16 (yammie tony)
