Anyone have exp with a hc_x roller secondary?
I had one on my mt viper for two years. Saw no gains and burned through belts. Was better at nothing IMHO than stock secondary. I went back to stock secondary.
i have had a hauck set up om mine since it was new 11k ago . never rode it stock . i just put in the 3rd set of rollers
used one for awhile and helped a member here with one set up, they worked well, have a good backshift if your riding alot of tight woods they work well. Found the best results with the smaller straight angles on the helix and you need to use a fair amount of sec. spring pressure to keep it from upshifting too fast due to the rollers moving on the helix ramp with alot less resistance, a silver secondary spring is needed.
