SRXXX
- Nov 11, 2003
- Reaction score
- 0
- Points
- 6
I have a 1999 SRX with a kinked tunnel and bulkhead. I have found a 2000SXR tunnel and bulkhead. Will this work without modification?
Sxr700Bandit
Triple Piped 700 Triple
I think the tunnels and bulkheads are identical.... YOu may want to check an online parts fische to double check.
BETHEVIPER
Life Member
Not the same . Your 4 heat exchanges are different as well as the front cast section.
Sxr700Bandit
Dag nabit I forgot about the heat exchangers... and didn't realize about the bulkhead.Sxr700Bandit said:I think the tunnels and bulkheads are identical.... You may want to check an online parts fische to double check.
ottawaair
Not sure where u r located, but I have a 2001 srx tunnel/ bulkhead from one i parted out.
jamie
Exactly!BETHEVIPER said:Not the same . Your 4 heat exchanges are different as well as the front cast section.
JDViper
Lifetime Member
- Feb 24, 2010
- Reaction score
- 0
- Points
- 0
- Iola, WI
- s1231.photobucket.com
I have all you need off of a 98. PM if interested.
