8" wheel kit question
fourbarrel
VIP Lifetime Member
Reaction score
14
Points
38
I bought a mono shock skid over the weekend and and in the process of tearing it down to see what kind of shape the bushings etc are in and wondered about the big wheel kit the guy I bought it from had installed.It is the offset axle type with the 8" wheels but only on the outside it still has the stock diameter wheels on the inside;would you not normally change the 2 inside ones to 8" as well?Even if it's with plastic aftermarket ones?To me it isn't taking full advantage of the larger wheels by having smaller/stock ones in the middle.
All four need to be 8". The two 7" inside wouldnt be doing anything.
Usually the inner wheels are offset so you can run smaller wheels. They only touch on the bottom so they give support underneath. Go to Royal Distributing's online catalog and look at their big wheel kit and read the description. The inner wheels are smaller and plain black plastic.
I just looked at royal distributing catalog. I simply cant understand the logic of having 8" and 7" diameter wheels on the axle. The catalog shows all four at 8" inch. Don't confuse the OEM column showing 7". The front axle has four drivers of the same diameter and the rear axle should match with four wheels same size. Now a drag racer different story may want to remove the center wheels to cut down on drag and increase efficiency.
There are billet axle kits out there that allow you to run the 8" wheels on the outside and the factory size wheels on the inside. I had a kit like this from MPI.
I have a kit that uses all 8in. I have used the other version and they work fine, the centers touch the bottom only where they are needed and keep the track centered. The only drawback is the looks are odd.
If your going to long track it at all you can get tracks usa rail extensions designed to run 4 8" wheels on the factory shaft. I had the offset axle and was not impressed at all. The track bows.
Dam i was eye balling that skid on kijiji...he wouldnt answer my emails...ya beat me to it...haha...oh well good luck with the install. Would like to get a bunch of us NB-TYers out for a day trip this season.
