bearing specs/ dimensions help!
j2hizzo
Reaction score
Points
16
southern maine
I'm getting.g ready to install a new track and I'm replacing both bearings. I have the bearing withthe lip that goes in the clutch side. I need the chain case side. I can get this bearing from a local manufacturer for 9 dollars, but I need the measurement to do so. I can't take it out then bring it to them as it will be thanksgiving weekend and they will be closed. Anyone any info?
the bearing is just a 6205 /2rs .if ya gotta have dimensions there 52mm o.d,25mm i.d,15mm wide with 2 rubber seals .
