Trailboss 03 Viper
I took the heat shields off my stock pipe for polishing and pipe painting.The straps were getting loose and starting to rattle,so I would like to replace them with adjustable ones.Does anyone know where I can find these? I'm sure an oversize hose clamp could work,but it would look like s***.
Trailboss 03 Viper said:I took the heat shields off my stock pipe for polishing and pipe painting.The straps were getting loose and starting to rattle,so I would like to replace them with adjustable ones.Does anyone know where I can find these? I'm sure an oversize hose clamp could work,but it would look like s***.
Other than Grienger's or Mcmaster-carr, you can find large stainless worm gear clamps in the plumbing isle (not the dryer/HVAC isle) at Home D.
Not as clean looking as the OEM banding strap which requires a special clamping tool and collar but if you place the worm gear on the underside of the pipes it ain't so bad.
If you go to a parts store, ask for windup boot clamps. They use a special tool to wind them tight but for the pipe covers, you can pull them tight enough by hand.
Trailboss 03 Viper
Thank you both for the advice.I went to Home Depot today and found 6.5 in. worm gear strap in stainless steel for $3 a pc. . SWEET!!
I have some of these on the way. I couldn't remember what length was required to get around the fattest part of the pipes so I just bought the 24" long ones. They are 5/16" x 24". They have other lengths also. Just be sure to get the 5/16" wide ones. The picture says 5/8" wide but they are actually 5/16 as it reads in the description.
http://www.ebay.com/itm/10-MONSTER-...ltDomain_0&hash=item53e74b7e29#ht_3810wt_1110
twyztid said:I have some of these on the way. I couldn't remember what length was required to get around the fattest part of the pipes so I just bought the 24" long ones. They are 5/16" x 24". They have other lengths also. Just be sure to get the 5/16" wide ones. The picture says 5/8" wide but they are actually 5/16 as it reads in the description.
Looks like someone flunked conversion 101 (they call the 4mm 3/8" - LOL) Very cool. Thanks for the link.
super1c
Super Moderator
snomofo said:Other than Grienger's or Mcmaster-carr, you can find large stainless worm gear clamps in the plumbing isle (not the dryer/HVAC isle) at Home D.
Just wanted to say thanks for info. Had to do a quick weld on my wifes viper pipe (blew a crack in it post back fire) and these will work perfect. $2 a piece at HD!
super1c said:Just wanted to say thanks for info. Had to do a quick weld on my wifes viper pipe (blew a crack in it post back fire) and these will work perfect. $2 a piece at HD!
My pleasure Chris. I sent my better half up to HD one day and she brought back the cheap-o ones and that's when I found out they sell both cheap-o's (in the HVAC isle) and stainless in Plumbing.
oh, and it was my fault ;>)
