heel-x sec kit
00sxrjoe
Maine
I am looking into buying this but the bolts and studs are missing. Think heel clicker can sell me them tryed to call today but must be closed. Are they worth it? And do they use cat helixs?
this is not it pic of the same thing
no they do not use cat helix it is there helix only no interference angles if ur not a clutch wizzard then u stick with stock clutching , in the right hands they are the best set up but u need to know primary set up right secondary spring to use and proper gearing to get max benifit
i ran one last year switching back to button style clutch not to inpresed
as for getting info. from heel clicker GOOD LUCK they have the worst costomer servive i have ever delt with
like i said u need to know clutch work one thing for cetain u need a heavier secondary spring than what is used on button clutches as they shift faster which bender has a special blue and white secondary spring that he built for his rooler rooster clutch when u figure out a rooler clutch u will never go back to button they flat out shift faster and are very good in the deep snow as they have quicker back shift verse button. all my drag sleds use rooler clutches
