seanmurphy26
i have a 98 sx 700 with PSI pipes and i put the main jet in but i dont know how to do the needle setting. they want me to change the setting on the center and mag to #4. i dont know what stock setting is. and i dont know how to change the setting. also when they say fuel screw are the reffering to the screw that is between carb 2/3? where you adjust the idle? they want that at 2 3/4 turns and stock is 1 1/2 so do i screw that in then screw it out 2 3/4 to get the right setting? thanks. im new to this stuff
seanmurphy26
got it thanks to topgunn a lot easier then i expected.
