How does this bracket bolt back on 99 SRX 700
sb2.2z28
ILL
Hello everyone! My name is Kyle, and I reacently picked up a 99 SRX 700 for $1500. :2strokes: I am in the process of changing out the track, and I cant quite remember how this braket bolts on to or around the brake caliper. I was hoping this would be a few hour project, but I have ran into a few bearings that need to be changed etc, and now am putting everything back to gether a few days after pulling it apart. Do anyone have a picture where this bracket bolts back in?
it is the bracket the coolant bottle sits on.Look at hole in bracket and hole at bottom of coolant bottle.It shows up perfect in your pic.The bracket sort of sits/snaps on the brake body and holds the bottle sturdy...
you probably will have to pull the hose off the coolant bottle in order to line it up properly..not much give to to move around..I had problem with same bracket years back when I did the same..hope this helps ya!!!!
