Power valve cleaning
Taphee
Chicago
just a quick question on power valve cleaning
I am going to clean the power valves and wanted to make sure (as I read the Tech section) you dont have to mark the position of any parts until you get to setting the valves. Is that correct.
Thanks much
I did number the cables and housing just to make sure they all go back to the original spot....
Well, you know its going to be a bad day when the first thing I do is break my torx wrench on the servo screw. Holy crud is that on tight.
