snoprokidf6
before i tear into my sled, for the plates that hold the sway bar bushings in the bulkhead. Are there 3 or 4 rivets in each plate, i'm going to be pretty bummed if there are 4 rivets.
I'm pretty sure there are four. I think one is kind of hidden behind the side body panels. You should be able to manually manipulate them(push them to the side) to get to them, like I was.
snoprokidf6
dammit...
yeah I ordered new plates for both sleds and bushings.But drilled out 3 rivets and lifted the plate upward to remove and install new bushing..but it was a royal pain in the butt.And the new bushings aren't really that tight..still play in them..piece of crap.I did 1 sled and never touched the other.I have 4 plates and a set of bushings sitting in the drawer..never to be used...
You would think they could of made sure that the plates were fully exposed..damn engineers I'll tell ya..they should be Fired or give their heads bang on the wall.
snoprokidf6
they should try working on them after they've designed something. haha
