smoothing weld lines
sxviper32
Valparaiso, Indiana
can i smooth out the weld lines on my 01 srx triple pipes with a grinding stone or will this make them weak? i was gonna smooth them out a little, no where near flat, just smooth em out and round off the lines a little better before i ceramakote them. thanks!!!!
you should be allright as long as you only grind on the weld it self and dont go into the edges on ether side of the weld. after something is like that is welded the weld becomes the weakest part.
