Hello,
When I took off my hood I was trying to unplug the white/clear conector that powers the headlight and the speedometer. In doing so the lock terminal and lock terminal o-ring went flying down into my pipes and I have looked for hours and cant find it anywhere, and I really dont wanna take my pipes off. So I need to find a new lock terminal or the whole connector. I have looked on the oem sites and cnat find anything, also I have been to the dealer and I cant get it either. So I was hoping maybe one of you guys have something. I have it taped up right now but it keeps pulling out causing my headlight and speedometer to not work. It would be great if one of you has it. It would be the female end. My sled is a SX Viper Mountain 700 by the way.
sandmaster
put a tie wrap through and around the connector with some dielectic grease in it.
cut the tie wrap when you need to unplug the connection
Hmm that's a pretty good idea I think I will do that. BUT am still looking for the replacment part.
chaddyg8
Do u have a pic of what you need? I have the whole harness from a 98 srx 700.
do a search for weatherpak connectors. find someone local that has put the $$$ up for their kits and check for a match. gm dealers seem to have the best selection, second choice is the electrical rebuilders(the guys that do starters and alternators). same stuff yamaha uses.
chaddyg8
Hey it looks like i have that female plug!! Send me your address and i will mail it to u. I will just cut it off.
Pm sent
