Phazer Front Coil Springs- Backordered
WNR18
Tisdale Sk
I have a 1994 Phazer2 ST The coil spring on the left ski is somewhat sagged. Tried to order a pair. 90501-752G6( long track) 90501-787F4(short track). Both backordered. Also tried a number for an Exciter 90501-703G8. Also backordered. Backordered may also mean not available. Anybody have any suggestions?
Are you sure it is not just a T.S.S link frozen ?
http://www.vintagevmax.com/vvforum3/viewtopic.php?f=2&t=1529
-T.S.S. Maintenance
On every used T.S.S. sled I've bought the Knuckles and steel bushing are almost frozen or completely locked up and pivoting on the bolts ! I've bought sleds that the locked up joints won't even allow the springs to return let, alone the struts to work when hitting a bump. The T.S.S sleds have always gotten a bad rap for slop developing when the ungreased steel bushing's freeze up they grind away on the nylon washers ! I have sleds that are 15+ years old that have never had a bushing kit and are almost as tight as new. Just take the knuckles and the ski mounts apart every other year and grease !
http://cgi.ebay.com/ebaymotors/Suspensi ... ccessories
Shim Kits http://s15106.50belowcommerce.com/produ ... oducts=tss
http://www.mfgsupply.com/m/c/100-650.html
http://www.schmidtbrosmotorsports.com/y ... -parts-vx/
http://www.vintagevmax.com/springrates.html
Not frozen. Sitting in shop. I know what you mean about grease. Greased everything last year. When you lift up on the front the left side moves more because it is sagged down. Had the shocks /struts out and they both have the same resistance.
