talked to my dealer and he told me had to send my crank back and get it replaced for 1300.00 becacause i cant buy bearings through yamaha is there any other way ?i have a crank guy who is great and done many others for me would like to save some money thanks
sxr1000 said:You are being lied to.
x2. I bought the outer crank bearings through Yamaha when I rebuild my 97 SX 2 years ago.
prostock 700
i was told for the price of all the bearing was about $900....so i ended up just buying a brand new crank!
staggs65
Ron,
who you having do your crank?
I heard CB Performance offers awesome deals on crank work
prostock 700 said:i was told for the price of all the bearing was about $900....so i ended up just buying a brand new crank!
Yeah, its pretty ridiculous.
for my 99 from port yamaha
1. BEARING for 1999 YAMAHA SRX700C/SRX700SC
93310-32009-00 3 needed $15.89 $47.67
2. BEARING for 1999 YAMAHA SRX700C/SRX700SC
93310-5270A-00 3 needed $55.38 $166.14
3. BEARING ASSY 1 for 1999 YAMAHA SRX700C/SRX700SC
8DF-11415-00-00 $160.85
4. BEARING ASSY 2 for 1999 YAMAHA SRX700C/SRX700SC
8DF-11425-00-00 $146.95
5. BEARING for 1999 YAMAHA SRX700C/SRX700SC
93306-20723-00 $67.60
6. BEARING for 1999 YAMAHA SRX700C/SRX700SC
93306-20722-00 2 needed $67.60 $135.20
7. BEARING for 1999 YAMAHA SRX700C/SRX700SC
93390-00028-00 $198.11
8. BEARING for 1999 YAMAHA SRX700C/SRX700SC
8DF-1142A-01-00 $46.44
9. BEARING ASSY 3 for 1999 YAMAHA SRX700C/SRX700SC
8DF-11436-00-00 $157.43
10. OIL SEAL for 1999 YAMAHA SRX700C/SRX700SC
93103-34181-00 $20.29
11. OIL SEAL,SW-TYPE for 1999 YAMAHA SRX700C/SRX700SC
93103-32153-00 $11.53
just had my outer bushings replaced at a performance shop. i had the hardware, but the labor was $50. cheap fix with some heat and a puller.
I was told the same thing from my dealer about yamaha not selling the bearings individually. The rational was that "back in the day" people were buying vipers and instantly messing with the cranks. Those cranks failed then those individuals were trying to use the warranty. So Yamaha finally said enought and only sells the whole crank assembly.
That's what I was told. However, my dealer said that there are some ways to get the bearings and have a shop work it. I didn't have to do this but he seems to be really spot on with all his info so far.
my 2 cents
my 2 cents
A couple of bucks
If you KNOW what the bearing dementions are...
http://www.gotbearings.com/
rx1jim
Contact Jeff at Midwest Crankshafts. He rebuilt a damaged crankshaft for my 2000 SRX: replaced two main bearings, a connecting rod and the connecting rod bearing along with welding the center crank pin for $300.
He is repairing a second crank for me which was repaired by someone else for the former owner of the sled. It needed an new connecting rod and bearing. Jeff is repairingthe crank for $180.
Jeff comes highly reccommended from several experienced members of this site.
x2 Jeff is the go to guy he was who yamaha used to repair the cranks under warranty
