sea foam in the gas tank
1yamaha1
nome
any body use sea foam in there sleds to run better and clean the system in the carb , sounds like a good prodect
Sea foam is pretty good stuff. I use it in my truck and cars to remove carbon and as a fuel system/injector cleaner. It can be used as a fuel stabilizer too, but it will not take the place of cleaning your carbs manually. There are too many small passages that get blocked and plugged and no amount of cleaner will get the crud out. If your sled already is running good it won't hurt to put a little seafoam in the tank imo.
Sea-foam is like gold in a can! I work for a marine repair shop and we use it religiously. I agree with sxr70001, it can work to an extent but if fuel has already started seperating in your carbs it wont do any good. I use it every time i fill up my boat, along with stabil ethanol treatment and have never had to physically pull off my carbs due to crud build up but i do take them off every spring to clean them anyways.
