will these trailing arms fit my SRX
Howden ,Manitoba,Canada
a guy has these for sale for $275. He says it fits a Viper or SRX.But aren't Viper's running longer spindles???I e-mailed him to measure the length of the spindle housing for me.Are these worth buying or junk..???
those appear to be the short spindle heads on those. do you know if the shafts are aluminum or chromolly? the heads are all chromolly.
personally i would stay away from them from my experience. the aluminum shafts break where they are pressed and if you ever bend one there are no replacement parts available. mpi doesnt make the tubes, havent for several years.
if you do opt to purchase them and need replacement tubes, i have made 2 sets from chromolly. not a dead on match but work fine in pairs.
that set up was around $400, new from mpi.
bluemonster1 said:
what do the Viper spindle housings measure??Mine on the SRX bushing to bushing is 6 1/8" approx....
mine measures about 7 1/4 inches aproxx. bushing to bushing on a viper.
If you don't buy, leave me his #, want a set for my new drag sled, by the way, they will be too short for your viper, the spindles will be to long, unless you run srx spindles, just won't have as much ground clearance.
I know the stockers on my 98" stood up at the end of a fire road crash last year. A new sled would have dis-integrated.....
