vmax secondary clutch
justheman80
Idaho
What secondary setting should I be using for a 95 vmax ST, it has a black spring with a pink splotch of paint on it. I mostly ride off trail and like to play on the hills. When I took it apart the spring was in hole 6 on the helix, but everything jumped when it came apart, so I did not see if it was in hole 1,2 or 3 on the clutch base side.
Honestly however it was setup before it seemed blaw. My Exciter would run circles around this thing up the hill, they both have the same track and the vmax has 10 more hp. The primary seems fine as the max rpm is 8000.
jus looked in tech section, should be red spring, 6 and 2 hole, 80twist,hope this helps ;)!
