sleddineinar
I pulled all the wheels off an x10 skid and repacked the bearings. I also pulled the arms off to repaint everything to guard against rust. Does anybody know what I should torque the bolts to when I put everything back together?
A couple of bucks
Best I can do is general torque specs. Tech section under misc, @ 6 topics down there are torque values for pretty much any smaller sized bolts and their composition. Should be applicable to pretty much anything I would think.
sleddineinar
Thanks. That's what I ended up using.
I always go tight....
At least that is the way we do it back home.....
A couple of bucks
Nicko said:I always go tight....At least that is the way we do it back home.....
German torque it............anybody,anybody
Torque wrenches are overated right....?
So anyways Andy, did we answer your question.....
sleddineinar
right... tighten it as tight as it will go and then give another 1/4 of a turn for good measure.
A couple of bucks
German torque = good-n-tite (spoken w/ a heavy german accent)
Tighten until it spins freely.
smokingcrater
A couple of bucks said:German torque = good-n-tite (spoken w/ a heavy german accent)
I prefer the TFAR method, which often goes along with the TLAR method of measuring...
(That Feels About Right, and That Looks About Right)
I always go snug and then some, usually pretty accurate... HA! Actually, I put a hub in my sisters focus last winter and my torque wrench was out of commission so, I used a breaker bar and my foot. Wasnt comfortable doing it that way so I called my old man up and had him bring his over. Ended up being 6 ft lbs. shy of my goal of 173. I've never gotten that close again.
