55ford
Just tested the stator on my 2000 SRX. The pickup coli tested out at 193 ohms, well within the parameters. The charge coil resistance was at .67 and the parameters are .36~.44, is there a +or - variable, is this stator bad. Gary
9801srx
.36-.44ohms is the +/-, .40ohm would be ideal .36 is minus 10% and .44 is plus 10%. at .67 it is out like 50%. i would check it a few more times to be sure you get the same reading before condeming it ,a little bit of corrosion on a connector can through such small readings off quite a bit.
Philsxviper
Hi , what you mean by charge coil ? because i got a similar issue on my viper .
problem with resistance checks are they have to be around a certain temp also, if its cold/hot the reading will differ.
whats the problem with the sled?
daletheman
- Aug 6, 2005
i have a brand new 8dn stator for sale
55ford
on my sled, it starts and runs fine, except it just dies randomly, starts right back up and runs a bit till the stator gets hot, then dies again, whether jack up in the garage or on the trail and the stator was rested at cold and warm temps and it stayed relatively the same. Mine's so far offtemp really isn't an issue.
