cant get clutches right, 01 srx
mattysmith440
Labrador City, NL
so, its the srx with the 8dn20's, 4.5 tip and heel, ywy, green secondary now at 80 twist, 8 tooth drivers and 1.75 track. AWESOME pull bottom end to mid range, then at top end bloooobbb. she loses it all and still stays at 7800 rpm. its especially bad when in deep snow...then it has no top end power at all. but even on a hard packed lake it just wont go past 8000 rpm, any suggestions? different springs? different twist? ive got a hauck "G" helix, which i THINK is 49/41. i just cant get it right
either change the helix wrap,helix or maybe your clutch is binding....Do you have your stock helix to try.Put the stock helix back on and see if you get back to the right rpm.If not then your clutch bushings may be binding..or take your parking brake off...lol
did you not drop your gear ratio for that track..what gears u running.It'll be like being in a car with standard and shifting from second into 4th gear.....takes a while to wind her up.
are u sure u don't have a pull thru power valve cable ???if not secondary helix is to big
powervalve problem when it wont go over 8000rpm, pull them and check for pull thrus and then repair, then reset them.
23/39 gearing right now. i havent checked the power valves tho, that could very well be my answer, because i know someone else with this setup and they are having no issues. and no, my parking brake is not on lol
with that gearing, you should b over revving. You arwe definately not loading the motor & will prob want to go to a 37 tooth bottom gear.
could be a broken cable or a pull thru, they arent that hard to take apart. Wait until its fixed, you'll think you changed sleds.
a broken cable most likely but a pull thru requires either a new powervalve or a better option in my opinion would be to have them serviced by one of the members here. They are prone to pull thru's just by the way they are built, and a new one will fail again eventually. Also a good idea to do all 3 while your in there.
http://www.totallyamaha.net/forums/showthread.php?t=64846&highlight=powervalves
so it was a pull through. lucky a buddy of mine had one in his garage that he had sent out to mrpowervalve? i think thats what he said. anyways put her back together last night, went for a ride this morning. what a difference. went about 10 miles, the on the way home was playing on some snowbanks, shootin roosters, and snap, there goes my cogshaft!! why would this happen!!!
mattysmith440 said:
snip - , shootin roosters, and snap, snip
Going from no traction to dirt whilst spinning the track will do it.
Kinda like snapping a car axle while spinning a tire from ice to dry pavement.
Something had got to give.
Judicious use of the throttle in such conditions will help avoid such damage.
Mine snapped in about 2 feet of powder. Pain in the *** getting it home. Yami dealer said he has seen many of the SRX front axles snap. $100 for a new one, and $75 to press and set the drivers. Might as well replace all bearings and seals while you are at it. Go over skid as well while it's out.
theres no dirt here in labrador, we have like 6 feet of snow already! i was in like 3 feet of snow playin on all the drifts. ive got my new shaft ordered already.
the reason its such a pain in the ***, is that 2 weeks ago I had everything apart to put my 8 tooth drivers and my new 1.75 track on. so all the bearings are replaced in chaincase, jackshaft, skid. so having had this all apart 2 weeks ago, just to do it again tomorrow SUCKS. but hey, stuff happens!
Ive heard of them snapping, but not right in the middle. A couple of the guys I ride with have had them snap right at the bottom gear
wow that is some dumb luck right there.. they say bad things come in threes. so you should be good to go after this one.
