02 Rear Heat Exchanger Install
yamahinn03
OSHKOSH WI.
I have a exchanger from an 04 Viper anyone got pics or advice for install? Do you have to cut tunnel for it to fit?
Not sure about mtn install. On shortie, you needed to remove the rivets for the back piece so that you could fit the pipe through.
Here is the scan of the directions. Not sure how it will turn out so here we go!
Try number 2!
