clutching
Gitterdun1985
Lincoln, New Brunswick
vmax800 with bender quads, reeds, reed spacers, cylinder lift. the clutches that are on it are stock it has 89a which weigh 60 grams in total a piece, white pink white with 1 shim in primary and rear clutch was set at 1-9 twist 100 degree. i need a setup that runs at 8950-9000 for these pipes.
RATHER SEE YA RUN 8BU-00 LOADED, SILVER SPRING IN SECONDARY AT 1-9. HAUCK BLUE SPRING OR A W-W-W YAMAHA WITH A 49-43 CAM. 3:16 (yammie tony)
