sockeyerun
Test Dummy
Which model of Fitch fuel catalist are you using in your sleds? Thanks, SOC
sockeyerun
Test Dummy
Where are you Blue?
hold your horses man..having breakfast here...lol.
I will look into it.Don't know the model right now..but it has to be the one that treats 10 gallons.There are smaller ones for smaller tanks like a weedeater and chainsaw.
never saw ths until today..should of pm'd me instead..lolsockeyerun said:Which model of Fitch fuel catalist are you using in your sleds? Thanks, SOC
F5T
For All Brands & Models of Snowmobiles, ATVs, Jet Skis, and Motorcycles
Also for Outdoor Power Equipment with engines ranging from 26-75hp and/or a 6-10 gal fuel tank.
Drop in tank application - for all brands and models of snowmobiles, ATVs, jet skis, personal watercraft and motorcycles (single, double, or split tank application).
Engine maximum 150 hp & maximum 10 gallon fuel tank. Must use both drop ins.
http://www.google.ca/url?sa=t&rct=j...sg=AFQjCNE4to7lbJHEyhV5g3o8IRYZrCTgHA&cad=rja
sleddineinar
SO, this stuff actually work? I've never known anyone who uses them.
now you know someone..me..Have been using for about 3 to 4 years now.Keeps the gas fresh and have not had issues with the carbs.I even have a canister mounted on my truck for Fitch Catalyst..my actual gas mileage has increased and starts really fast also.Got Fitch in every gasoline engine you can think of..snowblower,weed eater,chainsaw,pressure washer,irrigation pump,sleds,leaf blower,garden tractor,rotor tiller,IH Harvester Tractor,and truck.sleddineinar said:SO, this stuff actually work? I've never known anyone who uses them.
SWEDE
Blue, do those work with ethanol fuel like e-10 or e-15?
sockeyerun
Test Dummy
But bluemonster1, your usually always around and don't miss much, lol. I noticed you haven't been posting much the last couple of days. I figured you were riding. I am going to try these and wondered which ones you were using, that was the model I figured. Thanks for your help. Soc
staggs65
here's one of those never ending threads on it, http://www.totallyamaha.net/forums/showthread.php?t=41881&highlight=fitch
don't know about the ethanol issue...but I did a test with my Ford with the 351 motor.I did mileage tests going to and from work.I was averaging about 12 miles a gallon..conservative driving.I keep logs on my mileage and gas usage.Then I installed the Fitch Cat. Canister in the truck,spliced into the fuel lines as they instructed.Did more riding and tests.I was surprised how much my gas mileage went up,with same conditions and driving..wanted to really see what would happen.I ended up with around 17 miles a gallon after Fitch.And I noticed the engine starts rapidly now..like instantly as you turn the key..like instantaneous ignition..turn key..you can feel the motor just roar to a start..kinda like if you throw a gallon of gas on some garbage and then throw a match at it..thats how it starts/sounds.I was impressed..Works for me ..thats why I use it..
SWEDE
Sweet, good to hear that....
