setting carbs screws?
tomseal6
Brevort, MI
i just did some testing today and have some aggressive clutching kicks in at 4,800 RPM. i get a bog until it actually engages. i have fresh rings and a port job now. i know i have to take my screw out about anther half turn from stock because of the porting. how do you get to the screws and where are they? i hope this will cure this problem too
Tom, you have to take off the fuel lines, loosen carb clamps, remove, flip over the carb rack and they are in the front of the carb on the bottom side, turn them all the way in till lightly seated, then back them out 1.75 turns out. I would run the 42.5 pilot jets in that.
