Any of you mm guys ever swap in a Doo skid?
I swapped in an SC5 154 out of an '08 Summit X, it's a definite improvement over my last 2 setups but mine could use a bit more tweaking to get perfect.
Nice yeah I am working on mine right now and trying to get all my measurements all correct.
Here's a pic. I Think I'm going to lift and pull back the front mount about an inch, and I could use some fat boy springs. I saved 34 lbs over my extended extended stock skid by swapping this in.
suva57 said:Here's a pic. I Think I'm going to lift and pull back the front mount about an inch, and I could use some fat boy springs. I saved 34 lbs over my extended extended stock skid by swapping this in.![]()
SEXY!
On your front mount, how far back did you have to go
It's about 10.75" back from the drive axle (with the tape butted against the axle) and 12 73/4 in front of the stock center suspension mount hole.
The reason I want to move the front mount up is so the angle of the w arm or whatever they're called on Doos matches the approach angle of the track a little better, the tack gets a bit looser when the suspension is compressed the way it is now.
EDIT:
Here's a pic, BTW I have a 156 track
EDIT:
