2" pivoting riser for SRX and Viper
spwild47
Illinois
Any recommendations on a manufacturer for a 2" pivoting riser for SRX and VIper?
I would like to add these risers to help with handguard clearance..
Any notes on install would help too...
I installed those 2" ROX risers... Everything went well, but just make sure to crank them down well. Mine have slipped down a bit since installing.
Don't mean to hijack but his question relate's.
I installed the Rox 2'' pivoting riser's on my vmax,I had to replace the allen head bolt's with hex head bolt's but all the hardware store had was grade 5 bolt's not grade 8. Do you think i'll be safe or should I get some grade 8 bolt's.
Thanx
Not a huge difference between the two. I don't think you'd be putting anywhere near grade 5 forces on the bolts anyways.
Should be good to go.
